Reply
Intel AC7260 and Airport Express 5GHz disconnects FIRMWARE (1.0.2.64)
doubleroll
Apprentice
seems the 5 GHz just stops connecting to the Internet with th AC7260 and the Airport Express just disconnects from 5 GHz. I can connect to 2.4 GHz no problem. If I disconnect and reconnect to 5 GHz starts to work again. Did a 30/30/30 reset after updating to this firmware. Smart connect on as prior. Put all settings back actually from scratch. Any suggestions!
Message 1 of 5
VE6CGX
Master
Re: Intel AC7260 and Airport Express 5GHz disconnects FIRMWARE (1.0.2.64)
Wouldn't you have a better luck posting this on Intel or Apple forum?
Message 2 of 5
doubleroll
Apprentice
No I don't think that will help, since I never had disconnect issues with the prior firmware version. This happened when I updated firmware on the router, the ipad and laptop had no changes.
Message 3 of 5
DarrenM
Sr. NETGEAR Moderator
Hello doubleroll
Are you able to go back to the older firmware to see if it works again?
DarrenM
Message 4 of 5
doubleroll
Apprentice
Yes it seems to work with the old firmware.
This is the first firware that my Apple Airport Express disconnects and requires a reboot. The Intel Laptop connects automatically to the 2.4 Ghz and can be re-joined to the 5 GHz.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2013 views
  • 0 kudos
  • 3 in conversation
Announcements
