Reply
Intermittent outage when hot?
JesseeMay
It’s been unusually hot the last few weeks and I’ve been experiencing intermittent outage. My provider cannot reach my modem when this happens and my the rest of my neighbors in the apartment building are experiencing no issues. I reset, power cycle, etc. unplug and leave off and RE plug. All the things that I know to do. It doesn’t work. At least until the modem cools down. It’s in an open space with good airflow and seems to happen when temps get above 80. Any ideas? I’ve had for 14 months. Is this to be expected?
Message 1 of 6
microchip8
Master
Re: Intermittent outage when hot?
Get a cheap USB fan and let it blow at it.
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.88SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 6
Guru
what actual modem is it?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 6
JesseeMay
Sorry. It’s a cm600
Model: CM600|CM600 High Speed Cable Modem
Message 4 of 6
JesseeMay
Apparently I’ve got no idea what I’m doing. I had to look up usb fan. Ended up finding this video…interesting. https://youtu.be/FSQgY74yDzM
Message 5 of 6
Guru
I've never needed a cooling fan with a modem.
I have with a router that was in a warmer room for stability.
Might be worth just setting it on a little desk fan or laptop cooler if you have an old one sitting around to see if it helps. If it helps, then invest in a couple parts to try actively cooling it.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 212 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
