Reply
Internet Connection lost every couple of minutes
paxskins
Novice
I am having this problem over wifi, ping tests reveal it's happening at same time to two different devices, so I am narrowing it down to the router. I don't have a modem since our ethernet is hard-wired into our home from a control room.
Message 1 of 3
paxskins
Novice
Re: Loses Internet Connection every couple of minutes
So what was your solution?
I don't have a modem, and running ping-tests on two different devices show a timeout of service at the same time, which tells me something is wrong with the router.
Message 2 of 3
Babylon5
NETGEAR Employee Retired
Paxskins, you may have the same symptoms, but the cause of your issue is likely to be completely different, (so I split your posts to a new thread).
Since you say that your Internet is provided from ‘hard-wired’ connection it’s highly likely that you are connected to a router downstream, if you look at the WAN (Internet) IP address allocated to the R7000 is it Public or Private?
http://en.wikipedia.org/wiki/Private_network
If private then you could try setting the R7000 to Access Point (AP) mode.
____________________________
Working on behalf of Netgear
My name is Andy
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 5602 views
  • 0 kudos
  • 2 in conversation
Announcements
