- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet LED
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router LED blinking amber. Wireless is dropping throughout house even on computer in same room as router. Hooking modem to router by ethernet gives excellent download speed but doing the same from the router will not connect. have restarted both modem and router following recommended instructions. Have reset router to factory default. No changes. Received notice of firmware update but trying to do it throught routerlogin, it responds that there is no update. Firmware Version is
V1.4.1.50_1.3.10. Router is 8 months old.
Any help would be appreciated!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your model is R7960p correct? cause I don't see a R7960 in the support page. I do see a firmware update on the page for a R7960p https://www.netgear.com/support/product/R7960P.aspx#download You can manually download the firmware and apply it on your router by doing it hardwired.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet LED
Correction. Hooking modem to computer through ethernet gives high download speed but adding the router between modem and computer, it will not connect. Wirelessly the LED blinking amber.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet LED
Can you tell us what model number of router you have? Also which LED is blinking on your router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet LED
R7960 Nighthawk X6S AC 3600. It keeps erasing it from the model # space.It is the internet LED.
- Mark as New
- Bookmark
- Subscribe
- Permalink
