Reply
Internet: Solid Amber light
mtabikha
Follower
I unfortunantly woke up to this problem today. I went to my router to find out the internet light is solid amber. I ran into this problem about 2 months ago and fixed it myself by changing the mac address. This time it wont work and I've done almost everything i could to fix it, no good results.
This btw has NOTHING to do with the modem, everything works perfect on it
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Re: Internet: Solid Amber light
It may have everything to do with the modem. Perhaps the modem and router lost their connection at some stage – the amber internet light suggests that this may have happened – and you need to reestablish the relationship.
  • Turn off and unplug the modem.
  • Turn off the modem router and computers.
  • Plug in the modem and turn it on. Wait 2 minutes.
  • Turn on the modem router and wait 2 minutes.
  • Turn on the computers.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1591 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
