Reply
Internet dropout on r7000p
Frassan
I just bought a new router, the Netgear r7000p and I have an issue.
A couple of times a day the internet drops out, and I have to manually restart the router to get internet access again. I am still connected to the WiFi when the internet drops out and every led on the router indicates I have a connection with both the router and internet.
I use the latest firmware: V1.3.1.26_10.1.3
The internet drops on all the OS I use including OSX, MacOS, Android, Windows
I have full signal to both 2.4Ghz and 5Ghz band
I tried to disable Dynamic Qos about 2 hours ago, and it works so far (after some research here I found it could be the problem).
Either way the Dynamic Qos is one of the main reasons I upgraded to a new router.
So Q1: Do you think that Dynamic Qos is the problem?
And Q2: How do we fix the problem (Qos or other)?
Model: R7000P|Nighthawk AC2300 Smart WiFi Router with MU-MIMO
Message 1 of 2
Frassan
Re: Internet dropout on r7000p
Even witch QoS inactivated the internet drops out.
Its really frustrating not being able to have a steady connection with this new router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 464 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
