Jsnapp's avatar
Jsnapp
Internet keeps cutting in and out Netgear AC 1900
Need to find a solution. Two things:
1. Internet keeps cutting in and out
2. Ever since we put Netfear AC1900 in I can only group text group that are using an iPhone.
  • michaelkenward's avatar
    michaelkenward
    What does that mean? The Internet LED goes off? You lose a wifi connection?
    What is this AC1900? AC1900 is not a reliable guide to model number. Many devices come with an AC1900 tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    What is the model number?
    • Jsnapp's avatar
      Jsnapp
      So internet just stops working and then starts working again. It is every single day. Works for a while then shuts down. Then over time starts working again
      • antinode's avatar
        antinode
        Guru
        > Model: R7000|AC1900 Smart WIFI Router
           True?  Firmware version?  Connected to what?
           Visit http://netgear.com/support , put in your (actual) model number,
        and look for Downloads.  (For older versions, under Firmware and
        Software Downloads, look for "View Previous Versions".)  Find the
        kit(s).  What's available?  What's newer than your current firmware
        version?  Download the kit(s) you want.  Read the "Release Notes" file
        for instructions.  (In the User Manual, look for "firmware", and,
        especially, for a topic like "Manually Upload Firmware to the Router".)
        When that fails because of a deficient User Manual, try:
              https://kb.netgear.com/23960
