Reply
Internet "pauses" when using browser
proberts
Guide
When using a browser on a WiFi connected desktop connected to a Nighthawk R8500 the first webpage will immediately say the page can't be reached, and then within a couple seconds the page will automatically refresh and display the web page I was trying to access.  This happens with both Chrome and Edge.  It doesn't appear to do it everytime, but it has started doing it nearly everytime I open a new browser session and go to a new website.
When I opened routerlogin.net everything appears to be good, and it says Internet status is good.  I am getting the IP address and DNS address from the ISP.  Other IoT devices appear to be working properly, or as normal as they usually have. Speedtest shows speed to be normal.  All the Advanced Settings have green check mark except the guest networks which I have turned off.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Internet "pauses" when using browser
Try downgrading the firmware a version. A lot of different devices are seeing the same issue on DNS resolving on the latest release.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
All Replies
Guru
Message 2 of 6
proberts
Guide
I did recently do a Firmware upgrade before this problem started.  I will try that.  Thank you!
Message 3 of 6
Guru
let me know how it goes!
Message 4 of 6
proberts
Guide
Going back to the previous firmware version seems to have solved the issue I was having.  Thanks for the help!
Message 5 of 6
Guru
Glad you got it working!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 435 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
