Reply
Is Netgear R7800 capable with magic jack
EHOV
does anyone know how to set up magic jack on the R7800?
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 4
Guru
Re: Is Netgear R7800 capable with magic jack
YES. Mine is.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 4
EHOV
how did you set it up. the blue and and green light are on in mine not the yellow. when i plug the magic jack in the computer it works but when i plug it to the power outlet to use my cordless phone it does not work. And im not seeing the magic jack on my genie network.
Message 3 of 4
Guru
Need to use the USB to power adapter and plug it into a power all outlet. Then connect the LAN port cable from the MJ to the back of the router or external LAN switch thats connected to the back of the router. Thats how mine is connected. LAN cable connection with the router.
Testing
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2964 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
