Reply
HOLLA
Follower
Is it possible to disable login/configuration through WIFI? R7800
Model: R7800|Nighthawk X4S AC2600 WiFi Router
Message 1 of 3
TheEther
Guru
Re: Is it possible to disable login/configuration through WIFI? R7800
AFAIK, no. Just make sure you have a strong Wi-Fi password. If someone has cracks it, then that person will be on your home network and you will have bigger problems than blocking logins to your router.
Message 2 of 3
William10a
Master
Sorry that is true if your wifi is running your password is the only safety net you have unless you turn your wifi off then you just wasted your money for a wifi router.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 204 views
  • 0 kudos
  • 3 in conversation
Announcements
