- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is it possible to login to my router os/file system? Model (AC3600) NightHawk X6S
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there any way to SSH into the router/file sysetm for my router? I would like to be able to manipulate the way the router works, or is intended to work.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's neither intended nor supported. Many changes can disappear over uptime and almost certainly following a reboot due to the embedded system characteristics.
Some Netgear routers require a hack, other models offer the ability to enable a telnet access using /debug.htm
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is it possible to login to my router os/file system? Model (AC3600) NightHawk X6S
Thank you for the reply. I will most certainly purchase another router that proides this capability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Manufacturers of consumer grade routers do not want/like end users poking around and maybe trying to do some tweeking and breaking things then blaming the manufacturer.
Have to go toward the commercial grade side for ease of ssh and looking/editing files. I can log into my router via ssh but not a Netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Meghansuncle2 wrote:I will most certainly purchase another router that proides this capability.
An alternate approach would be looking for Open Source implementation - however there is not much around due to some limited open source driver support.
