× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Is the Netgear Nighthawk RAX50 worth it?
subevenis
Follower
The Nighthawk is currently at a fairly good discount at my local store, it has good reviews, but when looking it up on Reddit, there were a few posts stating that the router is "unstable". I.e dropping out, needing to factory reset after each firmware upgrade and low speeds etc.
I currently have the Asus rt-ac66u, but I'm not happy with it. Installing merlin did not solve my issues either. I consistently need to restart it at least once a day due to internet dropouts
So is the nighthawk a good router, and is it stable would be my question?
Message 1 of 3
microchip8
Master
Re: Is the Netgear Nighthawk RAX50 worth it?
I can't talk about the RAX50, but if you can pick up a RAX43 at a decent price, I'd go for it. Currently using one with only a few minor issues. Had an uptime of 60 days without any interrupptions before I had to upgrade its firmware
Message 2 of 3
Guru
You will find people complaining on the forums and reddit. Its where people go with issues. I'd recommend looking at the reviews on amazon and reading a few of the positives with the negatives. People are more likely to post if they have negatives but there's still going to be a few reviews.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 713 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
