Reply
Is there a modem router that allows
esancsufan
We are looking at the AC1900 wifi router and the CM1000 modem.  Do either of these, or any other for that fact, that allow you to turn off specific, individual website access?  In otherwords, if we wanted to keep our child from spending too much time on Youtube, can we turn off that specific site, but keep access to the rest for educational purposes?  Thanks!  Erik
Message 1 of 11
microchip8
Master
Re: Is there a modem router that allows
My R7800 has a "Block Sites" page. I do not know if the R7000 also has it.
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.91.1SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 11
schumaku
Guru
With these simple blocking methods available it's almost impossible to stop them using https or App based access to Youtube.
Message 3 of 11
schumaku
Guru
This AC1900 is what model? You might consider to deploy Circle -> https://www.netgear.com/landings/circle/default.aspx
Message 4 of 11
esancsufan
Nighthawk AC1900 dual band router with DOCSIS 3.0
Message 5 of 11
esancsufan
Circle seems like it might be a good option, too!  Thanks for that recommendation!
Message 6 of 11
schumaku
Guru
Afraid, it might be not available on your DOCSIS router.
Message 7 of 11
microchip8
Master
AC1900 is a speed class, not router model. I assume you mean R7000 https://www.netgear.com/home/products/networking/wifi-routers/R7000.aspx
Message 8 of 11
schumaku
Guru
Unlikley an R7000:
Message 9 of 11
microchip8
Master
I'm now confused. He also mentioned the CM1000 modem in his initial post
Message 10 of 11
esancsufan
We are considering both.  Sorry for the confusion, but this has been a big help with a big issue!  Thanks!
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 985 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
