× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 2 replies
  • 2048 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Is this normal?
Please excuse the newbie question but the R7000 user's guide suggests that the internet led on the front panel has but three possibilities: solid white, which indicates internet connection is ready; solid amber, which indicates an ethernet cable connection to the modem; and off, which indicates no ethernet cable is connected between the router and the modem.
I, OTOH, have a white light but it isn't solid. It flickers very rapidly. As I've only owned the router for a day I don't know if that means anything, perhaps an unstable connection to my ISP? Or is it just a normal indication?
Message 1 of 3
Highlighted
Re: Is this normal?
To make a long story short YES! It just means your device or network is accessing the internet or network is accessing the internet.
Message 2 of 3
Highlighted
Re: Is this normal?
Thanks. That's all I wanted to know.
Message 3 of 3
