dazzadasha
Dec 27, 2020Follower
Issues replacing Optus provided Sagecom with Nighthawk D7000 on NBN FTTP
TLTR Can I replace the Sagecom/optus NBN modem with a Nighthawk D700, or alterately can I bridge them?
Hi and thanks for reading . Im kinda just looking for some encouragement like "Its doable and worth it" before I give in. Before I hit up official support I wondered if I should even bother trying to use the Nighthawk D7000 for NBN. The salesman said "Oh it works and its easy to set up". well Ill be seeing you on Monday buddy. Ive had some limited very short lived success setting it up today( a few connections for a few minutes then it would kick us off and wed have to start setting up again) following "guides" online. My son even bridged it (Well he just plugged the nighthawk into the sagecom without changing settings, and we could choose both modems and had great speeds, but again it was short lived). But it would boot us off, as if it was limiting connections or something. Is it able to be officially bridged in this way? Im considering Aussiebroadband but Optus's plans are to my wife's liking. Happy wife, happy life, Right???. (more like happy wifi, happy life IMHO)
Thanks kindly.
1 Reply
Ah, NBN.
What NBN modem are we talking about? There seem to be more than one Sagemcom/optus modem. (Note the Sagemcom spelling if you are doing a search.)
Getting stuff to work on NBN can be a nightmare. The good news is that a lot of people have already grappled with the challenge. So there's a lot of past experience that you can draw on:
Search - NETGEAR Communities – D7000 NBN
You can try narrowing that down by plugging the name of your ISP into the search. Some ISPs have especially exotic configurations.
The problem is that NBN comes in many flavours, effectively it just means "Australian Internet".
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
Start by checking for your type of NBN.
While Netgear lists all manner of things as being "compatible" with NBN in that article, in reality this often means that the device will work as a router. You have to bypass the modem bit and use something else as a modem. Sometimes it is just the NBN box that your ISP installed.
Here's a good place to start looking for local expertise:
Remember, if you are transferring your modem/router from one type of NBN to another it is a good idea to reset the modem/router to that it forgets in past settings carried over from the old service.
Good luck, you may need it.
