Reply
Just installed a NightHawk RAX80 with firmware V1.0.1.56_1.0.23 and getting major DoS attack: Fraggl
AndreMartin1062
Just installed a NightHawk RAX80 with firmware V1.0.1.56_1.0.23 and getting major DoS attack: Fraggle
[DoS attack: Fraggle Attack] from source 192.168.150.215,port 5678 Thursday, Mar 07,2019 23:53:00
[DoS attack: Fraggle Attack] from source UNKNOWN,port 36022 Thursday, Mar 07,2019 23:52:59
[DoS attack: Fraggle Attack] from source 192.168.150.12,port 36022 Thursday, Mar 07,2019 23:52:58
[DoS attack: Fraggle Attack] from source UNKNOWN,port 5678 Thursday, Mar 07,2019 23:52:58
Any suggestions?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 7
microchip8
Master
Re: Just installed a NightHawk RAX80 with firmware V1.0.1.56_1.0.23 and getting major DoS attack: Fr
False positives. NETGEAR routers are notoriously known for this specific issue. Disable DoS protection, it does nothing anyways
Routing: NETGEAR RAX43 - Firmware: v1.0.11.112 (1 Gbps down, 50 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 7
AndreMartin1062
Are you sure network is lagging big time ?
Message 3 of 7
microchip8
Master
what "network"? your LAN or also Internet? The RAX80 comes with beta firmware so it's full with issues so it's difficult to tell. You're basically beta testing at this moment as this device is just out on the market with no mature firmware
Disable DoS protection and see if your network still lags. If so, then we'll go from there
Message 4 of 7
AndreMartin1062
You know when they a problem brings another. We in administration/log when I uncheck DoS and apply, it just goes page not found. Tried in Chrome and IE.
Message 5 of 7
microchip8
Master
Buggy firmware. In router land, the saying goes that you need to wait at least 6-12 months for the firmware to mature before buying the device. the RAX80 is just out and as I said, you're beta testing. If I was you, I'd return it and go for something else
Message 6 of 7
AndreMartin1062
Thanks for the suggestion. Might do that, I'll try a couple of things maybe if I can ssh in it. For tonight, closing the book.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1427 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
