Reply
LAN ports not working correctly HELP
hawkblood
Novice
Im trying to connect my xbox to my router via LAN cable and it isn't working. The cable works because when I use my modem to connect it it works fine. I don't want to use my modem because my NAT is strict and on my router my NAT is open.
Message 1 of 2
Babylon5
NETGEAR Employee Retired
Re: LAN ports not working correctly HELP
I’m not sure what you mean when you say you don’t want to use your modem? If you aren’t using your modem what is providing your Internet connection?
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5801 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
