Reply
Lan not giving gigabit speed using cat 7 cables.
Heromash
Follower
Help, please I have a R7000 and the lan ports are giving me amber lights when connected to laptop, using a cat 7 cable. Anyway to fix?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
storm1985
Prodigy
Re: Lan not giving gigabit speed using cat 7 cables.
isolation:
1. R7000 - cat 7 - another gigabit device
- if working, check your laptop's gigabit adapter
- if not working, go to step 2
2. R7000 - another cable like cat6/6e - gigabit laptop
- if working, then theres an issue with the cat7
- if not working, go to step 3
3. another gigabit modem or router - cat 7 - gigabit laptop
- if working, then there is an issue with the R7000. call NETGEAR support
- if not working, check the isolation on step 1 and 2
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3154 views
  • 0 kudos
  • 2 in conversation
Announcements
