Orbi WiFi 7 RBE973
Reply
Latest firmware release 1.4.1.68-1.3.28 will not load up
mgossling
Hi,
I am trying to upgrade my firmware to the latest release 1.4.1.68-1.3.28 but my attempts to do this via the app, searching via the portal connected directly to the router and manually uploading the .chk file have all failed to change the status from 1.4.1.50.
Has anyone else found this problem and hence found a solution as to how to load up the latest firmware?
Message 1 of 3
Guru
Re: Latest firmware release 1.4.1.68-1.3.28 will not load up
What router is it?
Have you contacted support at all?
Message 2 of 3
mgossling
Tried all routes open to me so far but only posted this morning.
I have tried to manually load up the file via the UI but no joy.
Nighthawk R8000P
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 455 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
