- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Latest firmware update bricked my R6020 Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The latest firmware update has bricked my router.
I've checked online and found a way to fix it but I'm not able to download tftp2.exe. I'm told I'm not allowed access. I've tried tftp.exe and Solawinds tftp server but to no avail.
I'm really quite pissed off because these updates aren't supposed to screw our hardware.
If anyone has a link to somewhere I can download tftp2.exe other than the shadowsoftware.net site, I'd be most appreciative.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
And many things can go wrong with both so when you say it doesn't work, it doesn't tell us much. tell us where its failing in the process, what you're trying, etc. details are key since we aren't there. And both tftp and nmrpflash are sensitive to timings. its a small window that you use when you start it.
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Latest firmware update bricked my R6020 Router
What symptoms do you see?
The "bricked" term is widely misused, with people using it to describe various problems.
One possible recovery option is a recovery reset:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, which is rare but worth trying, you may be able to use a traditional firmware upload.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You, sir (I'm assuming your gender), are a hero.
I cannot thank you enough.
I used cmd to tftp a firmware update and boom, it's all good again.
Once again, thank you immensely.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Glad it fixed it for you!
Let us know if you run into other issues
