Reply
Lenovo Yoga 13 failing to connect to R8000 Nighthawk X6 AC 3200 router following firmware update
Mr-SONY
My Nighthawk seems to having a failure.
WIFI has become unrealible and trying it hardwired (RJ45) only works sometimes with only a short
cable. It now won't work with my 75' cable which it did since first setup.
Being my cable connection is only running at 118Mbps directly connected to the cable modem
I can't see buying an over-kill router again only to get 1.5 or 2 years out of it.
It seems to me based on the download speed tests that a slower, cheaper router should be more then enough.
It's only me 97% of the time.
This router should be enough I think.
NETGEAR - AC1000 Dual-Band Wi-Fi Router
What does everyone think.
Thanks
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Mr-SONY
Re: Lenovo Yoga 13 failing to connect to R8000 Nighthawk X6 AC 3200 router following firmware update
Problem solved.
Replaced the Nighthawk X6 with an AC1000.
Nighthawk didn't even last 2 years.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 267 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
