- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Looking for a gbit wifi router nbn compatible ddwrt compatible
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Looking for a gbit wifi router nbn compatible ddwrt compatible
I'd probably look at the R7800. in that price range, has the feautres you want, has 3rd party software (which these forums can't/won't help you with).
Plus its been a fairly solid/reliable/good performing router imo.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree with @plemans .
The r7800 is probably the least screwed up firmware wise of the the Netgear line. Firmware on most others is just BAD, and seemingly no oversite. Other advantage is, as stated, you can run 3rd party on it should you want to go in that direction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
will it be able to be flashed with ddwrt i know i wont get the help here which is fine i just want to make sure i can use that firmware on it before i go out and buy it
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://dd-wrt.com/support/router-database/?model=R7800_v1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another R7800 fan boy here.
@plemans wrote:
Not to be evil but you have to do a little research on your own for 3rd party support.
It isn't evil to tell someone that it is a bit silly asking for advice here about alternative firmware. This is a Netgear community. While some people here are familiar with alternatives, genuine experts may be rare. And Netgear probably isn't keen to encourage such use. (It would break any warranty.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks?
Hope it works well for you.
