- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Looking for help to optimize gaming setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am new to this router and looking for some help or best options setting up this wifi with 2 Xbox ones and a PS4 pro. I enabled QoS but new to what this does. It actually says dynamic QoS. In the installation book says I can set the downstream and upstream but I do not see those options. Any help or suggestions would be grateful. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Looking for help to optimize gaming setup
If you unselect or disable Dynamic QoS then you and input manual ISP speed UP and Down values I believe.
Dynamic is good to use.
Be sure all game consoles are LAN wired to the router.
Be sure your ISP modem doesn't have a bullt in router, should be a model only if possible.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks. My consoles are wired and I purchased my own modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
