Reply
Losing connection
Bobj19
Follower
Losing connection
I keep losing connection to my router.  If I change the channel my devices connect again and work for a day or two then lose connection again.  Everytime I change the channel it works and then stops after a period of time and a new channel needs to be choosen.  I'm using the 2.6 connection for most of the devices because the signal for the 5g connection is not strong enough in most of my home.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Retired_Member
Not applicable
Re: Losing connection
Next time it happens try rebooting the device instead of changing router channel. Sleep mode or power saving options could be disabling the WIFI clients, check setup for the devices and try disabling.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1641 views
  • 0 kudos
  • 2 in conversation
Announcements
