tp30
Dec 31, 2020Follower
Lost Password EX7300
I purchased this through EBay a few years ago. I don't remember if I set a password or one was given to me but now I can't log into the EX7300. Is there a way to recover the password or factory reset it? Pressing the small hole/button on the side doesn't seem to help.
Thanks
When you factory reset, you have to push and hold for 7-15 seconds while its powered on. That should factory reset it.
- No1MportntLuminary
Here is a link to those instructions.
https://kb.netgear.com/000060616/How-do-I-perform-a-factory-reset-on-my-NETGEAR-range-extender
