Reply
Lost Wifi, can't enable it
Skip69
I suddenly lost my wifi connection. I can't change it when login to the router (enable radio wirelss router) and even the button on the router itself doesn't work. Do I miss something or is my router after five months use defect and need to bring it in for repair?
Message 1 of 4
Skip69
Re: Lost Wifi, can't enable it
I don't understand what happened. I couldn't activate the wifi in every way possible, but suddenly.. I could mark the box, which I couldn't before, and everything works again. It works on my nervs not knowing how this could happen and the software didn't work with me at first and did work with me after a coupe of hours. Very strange, but it's solved.. for now
Message 2 of 4
ringlord
Apprentice
Was this also on a R7000 ?
If so, check out this post : https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-R7000-wireless-option-unavailable/...
And yes the firmware from Netgear is buggy atm :-{
Message 3 of 4
Skip69
Yes, it was the 7000. I wasn't aware on any firmware updates. I suddenly lost internet and at first I blamed my provider.
I'll read that post. Thank you for mentioning.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2739 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
