- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lost username and password. Model R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I lost my router username and password. i can't sign in. Default username admin and password didn't work.
Please help me. How can I recover my router username and password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lost username and password. Model R7000
Only way it to do a factory reset at the back of the router there's a Reset button.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unless you set up password recovery and can remember the details you entered. But even that has problems.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
As @microchip8 says, if the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some memorable answers to those questions.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
