Orbi WiFi 7 RBE973
Reply
Mac OS ReadyCloud showing offline
nickstoy
Hello
Totally new to this, might be a dumb question.
I own 3 ios devices, an imac, and several windows machines.
I have a USB3 HDD connected to my R7000 Nighthawk.
I have registered and enabled the readycloud in the router setup page, and downloaded readycloud app on all ios devices.  I enabled media backup on all 3 devices, and it worked perfectly.  They each have their own media backup folder for easy identification.
Now, I want to close the loop by connecting my iMac into the mix.  I downloaded the software, it installed, but it shows as offline.
Furthermore, will I be able to have the itunes on my imac pickup pictures from these folders?
Thanks.
Message 1 of 3
Accepted Solutions
Guru
Re: Mac OS ReadyCloud showing offline
I think you'll need to re-post this in the home router forum.  Though this is "ReadyCloud", it is specific to ReadyNAS ReadyCloud.
Message 2 of 3
All Replies
Guru
Message 2 of 3
nickstoy
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3286 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
