Discussion stats
  • 3 replies
  • 97 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Malfunction of AC2300 smart WiFi router(Model:R7000P)
The WiFi router malfunction suddenly. The power button was in orange color and blinking continuously. And I can’t connect to the WiFi router anymore.
Message 1 of 4
Highlighted
Guru
Re: Malfunction of AC2300 smart WiFi router(Model:R7000P)
Did you try a factory reset? Push and hold reset for 7-15 seconds while powered on?
Or try a 30/30/30 reset? Push and hold reset while powered on for 30 seconds, continue to hold and power it off for 30 seconds, power it back on all while continuing to hold the reset for another 30 seconds.
CAX80->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 4
Highlighted
Guru
If that doesn't work, you might need to try recoving via tftp.
 if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 3 of 4
Highlighted
The manual will tell you what the LEDs mean:
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Check the troubleshooting section in the manual.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
