Orbi WiFi 7 RBE973
Reply
Maximum Wireless connections on 2.4GHz Nighthawk X6 R800
User661
Follower
What is the total allowed connections to the 2.4GHZ connection of the router? I have over 35 devices that need to connect and it seems to be limited to 30 devices at the time.
I understand that these are a lot of devices connecting to the router but they aren’t using the connection until a user actually logs in.
I have contacted support a couple of times and each support agent I spoke to give me conflicting answers from 60 devices to 40 devices an when I explain that I cannot connect any more than 30 they well then 30.
Message 1 of 2
Accepted Solutions
TheEther
Guru
Re: Maximum Wireless connections on 2.4GHz Nighthawk X6 R800
According to this Knowledge Base Article, the maximum is 32 clients per wireless band.
Message 2 of 2
All Replies
TheEther
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6717 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
