Reply
Media Bride Mode is unstable since 1.0.7.6
TCHAMMER
Tutor
Hi Folks.
Since i Upgrade to 1.0.7.6 in my R7000 and Reset und Reconfig it i have problems with the Bridge Mode. Everytime on Boot the R7000 connect to my Router from AVM but i cant enter to the Web GUI. My PS4 cannot get an IP Adress and i must restart the Router. After that it connects and The PS4 get the ip Adress but after a short while the PS4 Disconect and i see on the R7000 that the LAN light is going off and after 30 Seconds or more it come back but my PS4 couln´t get any IP Adress anymore. I must restart the Router again.
Now i´m Back to Version 1.0.7.2 and everything works no problems anymore.
I think it´s to early to set this Firmware as an Oficial Version.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
JamesGL
Master
Re: Media Bride Mode is unstable since 1.0.7.6
Hi TCHAMMER,
Try updating the firmware. Reset the router and manually reconfigure.
http://kb.netgear.com/000036470/R7000-Firmware-Version-1-0-7-6
Message 2 of 3
TCHAMMER
Tutor
Thx for the Replay.
If you read my post cearfully i wrote that i reset the Router After Upgrade to 1.0.7.6. I reset the Router Every Time After Upgrade or Downgrade and reconfig it.
I think the Firmware has bug's that Need to be fixed. Other Users in this Forum have Problems too with this Firmware.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1994 views
  • 0 kudos
  • 2 in conversation
Announcements
