- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mobile devices slow on Nighthawk R7900
- Mark as New
- Bookmark
- Subscribe
- Permalink
I noticed all of my mobile devices have slow internet speeds.. Both up and download speeds. However my MacBook and Dell XPS both reach download speeds above 110Mbps. I even tried testing my download speed on a relative's wifi network and was able to achieve speeds above 100Mbps on the first test.
I'm running dual band on my router and both are producing slow speeds.
Testing results on 5G
MacBook - 115.50Mbps
IPhone X - 25.64Mbos
IPhone 5s - 21.80
IPad 3rd Gen - 24.55
Testing results on 2G
MacBook - 53.85Mbps
IPhone X - 4.30Mbps
IPhone 5s - 16.60Mbps
IPad 3rd Gen - 4.64Mbps
Is anyone else experiencing slow speeds like this on their mobile devices? I've also reset my router and network settings on my devices. At a loss here.. Any help would be highly appreciated!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for replying and your suggestion. I attempted to reset my router again for the second time and it seemed to have helped my issue. For some odd reason I didnt see a change and encountered the same behavior after the first reset but after the second the speed was increased and is operating as it should.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mobile devices slow on Nighthawk R7900
Hi jrivera,
Try changing the channel of your wireless network.
Disable QoS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi jrivera,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
