Reply
Model R6900P orange light stays on after power outage
Tattoogrrl28
Follower
My router worked fine up until last night when the power went out. Ever since, the orange light stays on and I can't connect to the internet. I have tried unplugging it and letting it sit 30 minutes. I have also tried resetting it, but the light stays on and nothing changes even when I hold down the reset button.
Help! My teenager is not on WiFi and eating up all my phone plan data!
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 5
myersw
Master
Re: Model R6900P orange light stays on after power outage
Don't know all the reasons for the orange power light on this model, but normally means curupt firmware, but this is normall after an update that went bad. Since this is a cable modem/router, I believe, have you contacted the ISP to see if things to the modem look ok?
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 5
antinode
Guru
> Model R6900P orange light [...]
   There is more than one LED indicator on an R6900P.
   "R6900P" and "C7000" are not similar.
      https://community.netgear.com/t5/x/x/m-p/1622096
> [...] Since this is a cable modem/router, I believe, [...]
   A C7000 is a cable-TV modem+router.  An R6900P is not.  Look at the
attached picture?
> Router Netgear R7800 LEDE Firmware, Asus RT-AC86U Merlin Firmware
   Who cares?  How does that information help anyone?
Message 3 of 5
myersw
Master
Has helped folks believe it or not. Maybe I should add the Netgear CM500V modem plus Unifi Security Gateway to the sig. Smiley Wink Do not see anything wrong with giving folks choices.
--Bill
Tesla > Edison
Message 4 of 5
Greetings,
It appears your router is unable to boot.  Since you said it was subject to a power outage or power flucuation, its firmware might have become corrupt.
The article below decribes how to reflash the FW.
TFTP Reflash
Don't be intimidated.  Its not that difficult.  TFTP is a windows feature.  It has to be enabled to use.  Google it, its a check box.  Next , you will need a copy of the current FW your R6900P was running.  If you don't know which it was, grab the latest.
R6900P FW   1.3.1.44 is latest
The flash procedure is not hard.  Timing can be tricky, so don't get discouraged if it takes a few tries.
Post back if you need more help, someone here will assist you.
Moving forward, consider connecting the router to a UPS or at the least a surge protector which can help to protect from surges and outages.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Model: R6900P|Nighthawk Smart WiFi Router with MU-MIMO
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2528 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
