- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Model R7000 How can I turn on 5GHZ or how do I know if the 5GHZ is being used?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to make sure my laptop is using the 5ghz band. But I don't know how to tell the router to do that.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You DO NOT tell the router to do that, you tell the Laptop what SSID to connect to. Obviously you do not set both SSID's to the name.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Model R7000 How can I turn on 5GHZ or how do I know if the 5GHZ is being used?
This came up here not long ago. On investigation, the owner of the laptop found that their PC did not actually support 5G.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Dell laptop does support 2.4 and 5GHZ and the router does too. I just wasn't sure how to tell if and when 5GHZ was being used.
