Orbi WiFi 7 RBE973
Reply
Model c6220
Bethhall
Follower
Model c6220
I bought this router to replace xfinity one until they can come out to fix. But I can’t get it to connect to the internet at all
Message 1 of 3
antinode
Guru
Re: Model c6220
> fix. [...]
   "fix" _what_, exactly?  Is there some actual problem which you are
trying to solve?  Is it a secret?
> [...] But I can't get it to connect to the internet at all
   Just like your (unspecified) "xfinity one"?  Have you considered the
possibility that your (unspecified) "xfinity one" was not causing your
(unspecified) original problem?
   A vague description of what does _not_ happen is less useful than a
clear description of what _does_ happen.
   "can't" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual (at least).  Read.  Look for the
LED descriptions and "Troubleshoot".  Further reading might not hurt,
either.
   But, if your (unspecified) "xfinity one" was not causing your
(unspecified) original problem, then I would not expect replacing it to
help much.
Message 2 of 3
Re: Model c6220
Your subject says C6220. That's a cable modem.router. Is that what you meant to buy? Do you know that it is compatible with your Internet service?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
That is where users of these devices hang out.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 427 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
