Reply
Monitoring usage by IP on a Nighthawk R7900P
Tecomonster
Is there a way to monitor the usage by IP on this router?  I do not find it listed on the DD-WRT database.  Something on my local network is sucking down my rather limited daily badnwith limitations, and I should like to know what that is.
Thanx
Message 1 of 6
JamesGL
Master
Re: Monitoring usage by IP on a Nighthawk R7900P
Hi Tecomonster,
Are you using the NETGEAR firmware or the DD-WRT firmware?
Message 2 of 6
Tecomonster
Currently using the Netgear firmware, as I did not see the R7900P listed in the DD-WRT database as being supported.
Firmware version is V1.3.0.10_1.2.2
Message 3 of 6
JamesGL
Master
Hi Tecomonster,
You can check traffic meter but it monitors the bandwidth usage as a whole.
https://kb.netgear.com/24225/How-do-I-monitor-Internet-traffic-on-my-Nighthawk-router
https://kb.netgear.com/22734/Monitoring-router-internet-traffic-from-an-iOS-or-Android-device
You may suggest it under Idea Exchange board for monitoring per device.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Message 4 of 6
JamesGL
Master
Hi Tecomonster,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 6
Tecomonster
Thank you very much. For now I will keep an eye out on the DD-WRT database to see if my Nighthawk gets added to the comparable list.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1233 views
  • 0 kudos
  • 2 in conversation
Announcements
