- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Mounting An X10 R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
My current Netgear R7000 is mounted on a livingroom wall with the mounting holes on the bottom of the router. Can the new X10 also be mounted to a wall or does it need to sit on a shelf?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Unfiltered1
Welcome to the community!
Yes, you can mount it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Mounting An X10 R9000
Hello Elaine and thank you for the reply. Couldn't tell for sure from the pictures if the antennas would move into a position to allow hanging the router on the wall. This is my current setup. At the moment I'm gathering parts for a new build so it may be a while before I upgrade the router but the X10 definitely looks good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're very welcome.
Glad you're liking the unit!
