Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Moving from C6300 to X10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-03
07:37 PM
2021-10-03
07:37 PM
Quick question I just bought a x10 to replace my c6300. Can I turn off the wifi on the c6300 and connect the x10 into the c6300? Or should I buy a modem? If i have to buy a modem what would be the best option? Thank you for all your help in advance!
Solved! Go to Solution.
Message 1 of 6
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-03
08:07 PM
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-03
07:42 PM
2021-10-03
07:42 PM
Re: Moving from C6300 to X10
Configure the C6300 for modem only mode then connect the R9000 router to the modem. Can configure same SSID name and Password used on the modem on the R9000 router.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-03
07:58 PM
2021-10-03
07:58 PM
I am no very knowledgeable on your terms but it seems I can turn the wifi on the configuration then cat 5 to the x10, is that right?🤔
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-03
08:05 PM
2021-10-03
08:05 PM
You'll need to look at the user manual for your modem and find the setting that sets the modem to modem only mode or turns OFF router mode.
https://www.netgear.com/support/product/C6300.aspx#docs
Once this is done, then connect the r9000 router to the modem and install it using it's installation guide or user manual.
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-03
08:07 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-10-03
08:20 PM
Announcements
