Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Ms60 to ms60 via Ethernet
Nighthawk_25
Hi
Just bought a nighthawk mk63.
Router plugged in fine and one satellite upstairs gives me full download speeds over WiFi compared to wired. So that’s great.
However I want to have the other satellite ms60 in the garage. Only about 8-10 meters from the house but the connection seems to drop out every few seconds. The light is blue, then amber and so on.
I was thinking of getting a 3rd satellite and putting it at the opposite end of the room with the router so it’s only 4-5 meters from the garage. I suspect it’s the walls and insulation that’s the issue not the distance. If a 3rd satellite doesn’t work via WiFi, is it possible to use the Ethernet ports on the satellites to connect to each other?
Thanks
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Ms60 to ms60 via Ethernet
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 992 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
