Reply
Mutiple SSID's
Saleh9416
Mutiple SSID's
Hello
I want to enable multiple SSID's in my home network but I can't find the option!
Can anyone guide me how to do it?
Thank you.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 4
Guru
Re: Mutiple SSID's
If it has smart connect enabled, disable it.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
Saleh9416
Re: Mutiple SSID's
It's already disabled! but I want mutiple SSID's with different PPPoE accounts and different DHCP servers.
Message 3 of 4
antinode
Guru
Re: Mutiple SSID's
> [...] I want mutiple SSID's with different PPPoE accounts and
   Huh?  What does PPPoE have to do with a wireless-network SSID?
"different DHCP servers"?
   You might need to explain the actual problem which you are trying to
solve.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 245 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
