Reply
My Model R6120
ECArg9
My Model R6120
My WIFI Router third light stays on RED, I've updated the firmware, I've tried unhooked and re-hook, what else can I do to get rid of the RED light or is it something that I need to be concerm about? Earthea L.
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: My Model R6120
Are you having any issues with your internet or is it just the light is red?
DarrenM
Message 2 of 6
microchip8
Master
Re: My Model R6120
Red or Amber on some models means a device is connected at either 10 or 100 Mbps. The router has auto-sensing ports and during negotiation it can detect the capability of the connected device. If the device supports 1 Gbps, it will display white or green. All others below 1 Gbps are red/amber
Routing: NETGEAR RAX43 - Firmware: V1.0.11.112 (1 Gbps down, 50 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 3 of 6
ECArg9
Re: My Model R6120
Should I be concern about the RED light staying on?
Earthea
Message 4 of 6
microchip8
Master
Re: My Model R6120
No
Message 5 of 6
antinode
Guru
Re: My Model R6120
> My WIFI Router third light stays on RED, [...]
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for the LED
descriptions.  What does Netgear call your "third light"?  "RED" or
amber?  What's connected to the R6120?
> [...] If the device supports 1 Gbps, it will display white or green.
   Not if the router LAN ports are limited to 10Mb/s or 100Mb/s, as the
"Fast Ethernet" ports on an R6120 are.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 387 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
