Reply
My R7500 cannot see external drive Seagate 2TB USB 3.0 NTFS Problem
BoyanPetkov
Hi,
  I have an issue with my R7500... I cannot see the attached external drive which is Seagate BackupPlus 2TB UBS3.0
  I try to format is with FAT and everything is fine! But I want to use it as NTFS drive! Any idea or solution for my problem?
  If you need any additional information - please ask! Smiley Happy
PS For scientific research - I try to format it with EXT and Linux sees it, but Router still doesn't.
Model: R7500v2|Nighthawk X4 AC2350 Smart WiFi
Message 1 of 6
BoyanPetkov
Re: My R7500 cannot see external drive Seagate 2TB USB 3.0 NTFS Problem
Sorry for the bump Smiley Sad but I need a solution Smiley Sad
The External HDD is in supported list. If I format it with FAT - everything is fine, but I cannot put large files on it! That's why I want it as NTFS drive!
 Can you help me?
Message 2 of 6
JamesGL
Master
Hi BoyanPetkov,
1. What is the firmware version of your router?
2. Have you tried using a different USB drive and use NTFS?
Message 3 of 6
BoyanPetkov
Sorry for delayed reply, but I was at hospital Smiley Sad
1. Firmware is the last one - V1.0.0.94
2. I've tried with flash drive(16GB) that are formated with NTFS and it works flawless. I dont have other external drives except the one that I mention - Seagate Backup Plus Portable Drive, Model: SRD00F1, size 2TB
  Are there some logging system on those interfaces, so I can see where is the error? Or at least to find some clue...
Boyan Petkov
Message 4 of 6
JamesGL
Master
Hi BoyanPetkov,
I believe the route is working since the flash drive did work. Please try to format again your drive to NTFS and try to connect it again.
Message 5 of 6
BoyanPetkov
Hello again,
  I found that I can log ReadySHARE Smiley Happy so this is what log says when I plug the External HDD:
[USB device attached] The USB storage device () is attached to the router, Tuesday, May 10, 2016 15:55:54
nothing more Smiley Sad and I still cannot see attached anything in ReadySHARE settings Smiley Sad
Boyan Petkov
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1487 views
  • 0 kudos
  • 2 in conversation
Announcements
