- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My new Modem CM1100 Conect Router WNR1000 Not work
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a new Cable Modem CM1000. It work with LAN conection from Modem to my PC. I also use other LAN to connect with Router WNR1000 and no WIFI. The organ color can be seen on LAN at cable modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My new Modem CM1100 Conect Router WNR1000 Not work
> My new Modem CM1100 [...]
> I have a new Cable Modem CM1000. [...]
Which model is it?
> [...] I also use other LAN to connect with Router [...]
Who said that that would work?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "LAN 1 and 2 ports" and "Ethernet Port Aggregation".
Connecting more than one device to the LAN ports on a C1100 does not
work. As its User Manual says, "You can use the LAN 2 port to set up
Ethernet port aggregation." The second LAN port is not intended for use
with an additional client device.
Connect your router (WAN/Internet port) to the modem (LAN 1 port).
Connect your client devices to the router (LAN Ethernet ports or
wireless).
> [...] The organ color can be seen on LAN at cable modem
On _which_ LAN port? The WNR1000 (any version) is old, and has slow
Ethernet ports. Read the modem User Manual LED descriptions to learn
what an amber LED means. Read the WNR1000[vX] User Manual "Technical
Specifications" section to see the specifications of its Ethernet ports.
