Orbi WiFi 7 RBE973
Reply
My router does not allow me to save my DNS servers settings
Savier
Tutor
I'm not sure that I put the rounter name correctly, but if not, my router name is NighthawkAX8AX6000 WiFI Cable Modem
Router, Model CAX80. Since I got the router/modem i wasnt allowed to change my settings on my device. For example, when I try to change the DNS Servers, it doesn't save my settings, if anyone knows why this is please let me know.
Thank you
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 9
Guru
Re: My router does not allow me to save my DNS servers settings
what error are you getting?
what dns settings are you trying to use?
Again, what actually happens? Screen snips/better description helps.
Message 2 of 9
Savier
Tutor
I put 8.8.8.8 as my primary and 8.8.4.4 as my secondary DNS, than I hit apply and the page refreshes like it does when I try to apply something on the site. But nothing saved, the text becomes empty, and I know that I didn't not get any errors because before I put the wrong DNS Server and it gave me a error. I do have some boxes for Internet Setup page that say undefine, I don't know if thats maybe part of it or the reason,
Thank you.
Message 3 of 9
Guru
got a screen snip of the errors?
What firmware is on the router portion?
Message 4 of 9
Savier
Tutor
I do not have a error showing up, the page just refreshes, and my firmware version is V2.1.2.6
Message 5 of 9
Savier
Tutor
Sorry for the slow reply
Message 6 of 9
Guru
You have the RAX80? The latest firmware is 1.0.5.126?
Message 7 of 9
Savier
Tutor
I have the CAX80
Message 8 of 9
Guru
Please visit and post about this over in the Cable Modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1374 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
