Reply
My setup - Tips and Advice?
Armorless
Greetings, i am fairly new to the forum and was looking for assistance to make my connection as stable as possible as i play PS4 competitively.
My setup is as follows:
Tecnicolor 4400 Modem -
Cable: 940/40 speeds - Actual - 935/39 at 15-20 ping
Netgear R8000-
Turned off SIP ALG
Turned to “Open’ setting
Custom wifi settings(name/password)
Newest firmware of V1.0.4.18_10.1.49
Time set to eastern
All else is standard
3 PS4s, Desktop, Xbox one are connected via wired
Only two PS4’s and desktop are usually connected online at once
I am running a 100ff CAT 5e from downstairs to upstairs bedroom connected to a gigabit switch upstairs which connects the systems and PC.
What can you all suggest to make my experience better? I absolutely love my netgear products and would like to keep them. Am i missing something? Can i do anything better? I will appreciate any and all advice/tips. Thank you and sorry for the long post
-Armor
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 9
DarrenM
Sr. NETGEAR Moderator
Re: My setup - Tips and Advice?
What issues are you seeing while gaming?
DarrenM
Message 2 of 9
Armorless
Hello. I an having light spikes. So it will fluctuate from lets say from 15 ping to 55 ping on a quiet connection. Or 15 to 30 to 55. There are times where my connection drops to about half of what it should be
Message 3 of 9
DarrenM
I could be a ISP issue are you able to post the event logs and power levels of the modem? typically you can get to the modem settings by visiting 192.168.0.1 or 192.168.100.1
DarrenM
Message 4 of 9
Armorless
Hello. I tried logging in. I do not have access to the modem so i am unable to post. I will say i have 13-15 devices in my household on. But all my stuff is wired that i personally use and all else is wifi. Anything else i could do?
Message 5 of 9
Armorless
Hello and sorry for the late reply. Every time i try to do the test it can't do my upload speed. Is there a fix to this?
Message 6 of 9
Armorless
I managed to finally log in to my modem after digging deeply for it.
Message 7 of 9
Armorless
Message 8 of 9
Armorless
That doesn't help any. I've done a ton of research. I have tried just about everything. You make it seem like the product is flawed. Why not say, "buy a new router"?
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1159 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
