Reply
NAS Readyshare
allanw
Novice
NAS Readyshare
Hi,
I have tried to rename the USB share names in the advanced ReadyShare page. But when I select a USB drive and click edit the page just refreshes and does nothing else. So I cannot edit the names. It would not let me create folders nor change any access rights.
I have both USB2 and USB3 drives plugged into their respective ports. The drives work fine. (A little slower than I thought) but still fine. My biggest concern right now is not being able to edit the properties.
I searched throughout the forum and cannot find anyone else with the same problem.
Anyone else experiencing this or know why I am?
Thanks,
Allan
Message 1 of 2
allanw
Novice
Re: NAS Readyshare
Wow. That was an easy answer. Just for others that have the same issue. (I have not tested this yet.) But it seems it could be a popup blocker on my browser stopping me from seeing the proper page:
http://forum1.netgear.com/showthread.php?t=89312
I ended up spending over 1 hour online with support who had me re-flash my router to end up at the same spot.
Anyway, if the popup disable does not solve the problem, I will report back. If it does then . . .
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6495 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
