Reply
NEED!!! an 8 port option.
Mythre
Follower
https://www.netgear.com/home/products/networking/wifi-routers/R6850.aspx
So I picked this up a while back and I NEED this, but with 8 ports.
This exact type/style for 8 ports.
All I need is a LAN switch with a wifi broadcast that has 8 (4 additional) ports.
Long story short, this unit solved every problem I had with modem/routers and them not communicating well with other brands causing ping loss.
It was a mess, but this simple little unit was a godsend.
Just needs more LAN out ports (;_Smiley Wink
Model: WAC124|AC2000 Dual Band 4x4
Message 1 of 2
microchip8
Master
Re: NEED!!! an 8 port option.
Why don't you buy a cheap 8 ports Gbps switch instead? I'm not aware of NG selling routers with 8 ports. ASUS has one, the AX88U
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.89SF & Kamoj addon
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 16 TB
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 121 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
