Orbi WiFi 7 RBE973
Reply
NETGEAR Certified Refurbished AC1600 WiFi Cable Modem Router (C6250)
nayanmahanta
Follower
I Have NETGEAR AC1600 WiFi Cable Modem Router (C6250). When I am browsing net through router some specific website are not opening for example Instacart, Wellsfargo.com etc. But other website are working fine i.e Chase.com or Walmart.com etc. When I am connection throught mobile hotspot data(T-mobile) it working perfectly fine. Is that issue with router? Do I need new router to resolved this issue ? Please suggest.
Thanks!
Nayan
Message 1 of 3
Guru
Re: NETGEAR Certified Refurbished AC1600 WiFi Cable Modem Router (C6250)
try a different dns provider.
You can try googles at 8.8.8.8 or 8.8.4.4
cloudfare's is 1.1.1.1
Message 2 of 3
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 388 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
