Lil_Evil's avatar
Lil_Evil
Follower
Nov 14, 2021
NETGEAR NIGHTHAWK AC750 (R6020)
HELP PLZZZ Can I bypass using the NETGEAR NIGHTHAWK app ??? And jus hook up the router and also RUN it to my laptop using a ethernet cable? I dont want to have to use thw app........:smileysad:  THis riuter is driving me crazy
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Yes,
    Just plug PC into router and launch a browser at the graphical user interface (GUI).
    The manual tells you what to do.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    That works for just about any router, but if you need advice specific to your particular router, try here:
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware.
    General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
