Reply
NETGEAR NIGHTHAWK X4S AC2600
joyceanna46
Follower
My Netgear Nighthawk router will not hold a signal from my server.  It disconnects sometimes 30-40 times a day and has to be reset.  My internet provider has checked my entire system over the past 8 months several times. I pruchased this router to repalce another Netgear Nighthawk that my internet provider told me was no longer getting a signal, althought it was only 18 monts old.  For several years, I never even had to reset my router until the previous one failed.  Every wire and setting has been changed to try to improve this situation by my provider.  Still, today it continues to disconnect every few minutes.
This is my fourth Netgear router.  One of the previous models is being used at my parent's house and has not problems.  It is about 4 years old.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Guru
Re: NETGEAR NIGHTHAWK X4S AC2600
What firmware is on your router?
what modem/gateway is it connected to?
Any switches in line between the router and the server?
Is it only the server having issues? Do all wired devices? Only wireless devices?
What is your "whole system"?
Since we aren't there, details are important.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 75 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
